I've got a problem with the wiring 😭 shorting | on ElectriciansForums
Discuss I've got a problem with the wiring 😭 shorting in the Auto Electrician Forum area at ElectriciansForums.net
Victoria
I've got a problem with the wiring 😭 for some reason I've got no break lights they stay on and only when the headlights are on and I have no Parker's but if I put the Parker's on and put my foot on the brake they come on but as soon as a take my foot off they turn off and now I've got a headlight one dinner then the other 😭 FML seriously
Most likely a ground fault, check for corrosion of wires or terminals that connect to the chassis or body panels, particularly around the back of the car to start with.
Reply to I've got a problem with the wiring 😭 shorting in the Auto Electrician Forum area at ElectriciansForums.net
Ok, after trying two different flashers supposedly for Led bulbs, I got one that also has a ground wire, and it worked. I now have operating turn...
Thanks a lot FG; Thanks for that solution, I was looking along the same direction and yesterday ordered two 5 pin 12v 40A relays from Amazon and...
