I salvaged a 5KV Tx out of an old microwave and made a Jacobs ladder. I have not been able to get the arc to rise yet unfortunately.
Has anyone made one of these before? and if so what sort of transformer did you use?. I have been looking for neon sign ones but can't seem to find any for sale in the UK.
An odd question perhaps, but it's just a bit of fun really.
Thanks :smile:
I made one as an apprentice which was only a few years ago (maybe 35). I used a flyback transformer out of an old TV. If you mess around with that type of tranny be very careful, they will give you a whack large enough to knock you into next week or even the next life.
What KV was it out of interest Mate?
I am sure 5KV is enough for it to work but it does not say what current.
People seem to be using neon sign 10KV 30ma ones and getting good results.
Look in the things to make and do section of bigclive.com he's got a write up on it somewhere.
You can start the arc by adding another small electrode between the two main ones and connecting it via resistors to encourage the arc to start.
I've got a neon sign transformer sitting in the warehouse waiting for me to build one of these
Thanks, i will take a look at that site.
If i get it to work i will post a vid up of it.
It works a treat. I am going to get some copper pipe and make a twister rather than the arc just rising. I would post a video but not sure how to get it off my camera right now.
I've never heard of the twister, maybe it's a more recent fad but the rising arc between two wires tends to work better if the wires are perfectly straight and the gap at the top is only very slightly larger than the gap at the bottom. We also used to use just single core straight wires, I'm not sure if the twisted wires will affect its performance. They're a bit finniky and need some delicate fine tuning to get a good effect usually.
Twister may not of been the correct term to be honest. This is what i want to make. :)
https://www.youtube.com/watch?v=-AsaGgb5ixo
I have a flyback and am wondering how i know which is the primary i am after. I have tested with a multimeter and am getting the same reading across a couple variations. From some videos i have watched i am looking for a reading that is close to one Ohm, or is it different for each flyback? I am also getting a reading of 0.5 ohms between pin 1 and pin 3. Thanks in advance for any help. :)
It's always fun and games figuring the pinouts on a flyback. Have a squiz at this, 30kV Flyback PSU | GardenBallistics
I'm gonna say this again even though I'm sure you're already aware. Be very careful, a flyback can give you a whack big enough to knock you on your --- or even into the next life if you're really unlucky.
Got another transformer so paralleled the primaries and the secondaries are in series. Bigger arcs and a wider gap like this. pops the 13amp fuses after a few continuos goes though. :smile:
Very nice :) ...maybe go with a C-curve mcb if your impedance is low enough to still achieve disconnect times or is it the plug fuses that are popping?.
Got them on a plug top at the moment. Can get a couple arcs then the 13 amp 1362 fails. :shades_smile:
Lol, I forgot you have 13A socket outlets in the UK, I'm used to the 16A sockets we have here. If you carry on expanding your system you're going to have to install a shower circuit with a 32A commando socket for your experiments ;)
Yeah i got a couple of spare ways in the consumer unit. :teeth_smile:
South West, Bath
Jacobs ladder.
Electrical Course Trainees Only
Thread Tags
Tags Tags
ladder
Simonslimline,
Simonslimline,
