Jaguar XK in cabin electrical whining noise | on ElectriciansForums
Discuss Jaguar XK in cabin electrical whining noise in the Auto Electrician Forum area at ElectriciansForums.net
Jag1
Il
Hi all
I hear a whining noise in cabin, AC off, audio off
It is relatively low volume and the noise pitch follows exactly the motor revs
Seems like an induced noise...
Any idea what to look for ?
Hi all
Anyone in your locale missing a Cat?
Audio gear .. thru speakers ? Amp still active ?
( if electrical load dependent - add heated screens /lights to see if it changes- alternator interference)
... not an XK expert ... so could be power steering pump for all I know.
(any toothed belts changed recently ?)
Audio...there is only head unit, no amp, so I shut off the audio main switch
I may disconnect the speakers wires just to make sure it's not there
Not sure I understand what you mean by ad heated screens
How can I check if power steering may be the cause?
No belts change lately, however, I own the car for a few months...
Thanks a lot
Ad heated screens = Turn on a few (quiet -High drain loads)
no fans , heated seats , windows ... sorry should have been add +
(if any belts were over tight - may whine .. transmit more noise into body of car ) .. a lot of these noises may be normal , need to compare with someone else .
( My whining noise was a jammed viscous fan - sounded like a super charger .. but pedestrians did notice me )
N o he has Westward 10 in the passengers seat, should have added that's in fun no offence intended Westy
Sorry Mate, but you must realise many of us aren't Motor Mechanics, as much as we appreciate your patrimony, maybe a Vehicle electrical forum would be more able to advise you on strange noises emanating from your MV.
Why bother posting then?
What... a bit like the auto electrical forum we have here that this thread is posted in?
Reply to Jaguar XK in cabin electrical whining noise in the Auto Electrician Forum area at ElectriciansForums.net
Thank you for the suggestion!
On a small generator I wouldn't want to risk using diversity as they are not quite as forgiving as a mains supply and can very quickly fail when...
