C
claret73
No longer having access to the Manufacturers instructions, is there (specifically to this make) or a general 'Best Practice' or even a Reg to Building Regs minimum distance from the top of the downlight case to the floor above?
Looked at JCC's site & cannot find anything specific.
Another quickie on this. We've done a few of these & looped to each fitting with .75/1.5mm flex. I've just found a post where it mentions running in cable to withstand the heat generation if the cable runs in proximity to the fitting. What do you guys recommend on this?
Cheers
Cheers
