A
alexknight0602
Got 2 questions if you guys/girls could help and advise
Supply is TNS
Job is supply to garage for power and lighting. Please don’t be thinking here we go again as I have read endless amounts of threads on here so I am fairly clued up. These are questions specific to this install.
Q1.
There is already power there in the form of a radial circuit, but it comes from a 4 way MEM fuse board and is spurred off a ring at the fuse so cant be used. Im not going to use this fuse board as no spare ways and there is a separate CU next to it, which is used for the shower. BUT I noticed that the earth sheath cable is connected to a nut and bolt (make shift MET) past this point it has been cut in the past and isn’t connected to the MEM fuse board. The earth that is connected to the fuse board is connected to the main water supply. Even though im not using this board should I fix with a new CPC? Does this mean I will have to test the whole board after? Picture attached to help.
Q2.
From what I have read so that I don’t have 2 RCD’s in series I should have a MCB the other side of the RCD on the board. I am not very familiar with different board layouts and to me it seems as if there is no main switch just an RCD and the MCB for the shower. Can this be moved along the bus bar and the MCB placed there? Again picture attached. CPC for this board is connected to the nut and bolt/MET.
Supply is TNS
Q1.
Q2.
