C
ch657
hi i am going to price a full rewire to a 2 bedroom fairly large bungalow tommorow (which is my first) i am fully qulaified and have experience but not in pricing jobs.
i really ont want to over charge and not get the job and i really dont want to undercut myself.
i would like to know what to charge roughly for each point £30 - £60? and does this include the labour and materials cable ect.?
how much for a consumer unit change? also does it include cable and material pricing.
cooker points , tv points, lights everything.
any help would be appreciated a lot.
thankyou.
go for £45 per point ( treat a light switch as a point ) for standard plastic accessories. shower and cooker points at £80 per point. add up the total , say it comes to £2800, then estimate the cost of materials and time to do the job. then go for the higher of the 2 totals. if going down the RCBO route, add the cost of the RCBOs.
thanks telectrix has really helped. does that pricing include all of the labour and cable? also would you class the consumer unit as a normal point?
thanks
Easiest way really is to total up your material cost £xxxx
Then number of hours it will take x your rate £xxxx
Add a few quid for contigencies £xxxx
Add any other costs (cert fees insurances office exps etc) £xxxx
Any other costs you need to cover
Total them all up and theres your price
this is where you have to use your judgement. if the per point pricing looks too low when you've costed out materials and labour at , say £20 per hour,, then shove the per point price up a bit. i would guess a final price should be around £3000 +/- £300 unless there are loads of sockets, downlighters etc.
Job Pricing help please
Australia
ch657,
ch657,
