Job | on ElectriciansForums
Discuss Job in the UK Electrical Forum area at ElectriciansForums.net
L
lofty84
Ive been asked if I can do the a very simple job for someone, all it is is to change the faceplates from plastic to chrome on the following
8 x double sockets
1 x single
5 x dimmer switches
1 x normal switch
5 x switched fused spurs
1 x aerial socket
1 x telephone
how much would you charge for that please?
Many thanks
8 x double sockets
1 x single
5 x dimmer switches
1 x normal switch
1 x aerial socket
1 x telephone
Many thanks
if its labour only ÂŁ150 decent half days work
Just to change a front ????
Thats about ÂŁ60-70 perhour ?????
Work for an oil sheik do you lol.
How long does it take to take off old front, strip back cables, untwist earths if twisted, re-sleeve earths , strip conductors, put new faceplates on, probably not long, but then if you allow for b***x such as, cables not long enough, broken lugs, and some of the new fuse spurs are a nightmare to fit in the backboxes especially the flat plate ones, I always go with ÂŁ10 per point, for changing accesories, be it a socket front, lightswitch, or wall lights and changing normal pendants for fancy things from B&Q !!! no-ones ever told be its steep, even had a guy give me ÂŁ20 just to replace a 6" pendant like for like said i was too cheap!!
best one i had was changing all the socket, switch and spur fronts in a big 5 bed 2 bath house, 97 front plates in total, @ ÂŁ10 per point done over 2 days, and they supplied the accesories
8 x double sockets
1 x single
5 x dimmer switches
1 x normal switch
1 x aerial socket
1 x telephone
Many thanks
I would charge my day rate and hope all goes well.
Bear in mind that you may also find that you have to connect fly leads to earth the metal accessories. You may also discover no rubber grommets fitted to installation boxes which will need rectifying too:thumbsup
As mentioned a very simple job can turn into a right ballache :(
Also, I think you should think about even if you complete the work ahead of schedule it won't leave you a great deal of time to move on to another job so in my opinion it has to be a day's work at the absolute minimum.
Reply to Job in the UK Electrical Forum area at ElectriciansForums.net
i am looking at outdoor security lights, hard wired with PIR sensors but there are so many options .. any suggestion on brand or what to get would...
