Jobs that require downlights | on ElectriciansForums
Discuss Jobs that require downlights in the Australia area at ElectriciansForums.net
Amp David
Mentor
Glossop
When ever you have a job that requires donlights, do you explain to the customer about the different types on the market regards cost savings ect, eg LED/CFLs instead of halogen, or do you just do the quote with what ever kind you usually fit.
Have tried now on a few occasions to get the customer to go down the enrgy efficient route of CFL or LED, but no chance they just go for the halogen jobbies. Probably down to the cost I know.
Its just that lately everywhere you look theres a report on halogen spot light cause fire and the like and has got me wondering about using them.:eek:
I go through it with them on every occasion, and very often they will intend to get the LED ones in the future.
The problem is definitely the cost (off the top of my head a LED GU10 is something like ÂŁ15-20,a lamp, for me anyways). Some clients however, are fed up with their existing halogens blowing, and they're more easily converted.
On another note, I wired up a house last year which was being refurbished to let. I sneakily suggested installing pendants on the stairwells and landings that would only accommodate CFL's. They went in great and the tenant thought that they were a really smart idea, until his wife had to find lampshades she liked (the base of the lamp holder is bigger). They very nearly came down, but my wife spotted some that fitted when we were focus one time which saved the day.
Building inspector was impressed with the consideration in my design :p
YES ITS JUST THE COST THAT KILLS IT.
but ive got a few people to go for it and carry a few sorts to show customers.
some are more conserned with the quality of light rather than just cost..
but these are a bit few and far between..mostly older people with poor vision and that.
the robus led gu10 multi led and chip tec lamps seem to be good and can replace a 35-50w halogen.
anyone else got thoughts on this
i give them the options and let them choose. depending on the customer depends whether they bother to listen. luckly enough the ones i have had don`t just go for the cheapest option they normally ask "what would you install in yours"
Everytime I'm asked that I shoot myself in the foot and say 'I wouldn't install downlighters'. It's like a bad habit, or instinct or something.
Then they ask me why, and I keep shooting myself in the foot.
Do you know of any good value GU10 LED's that fit existing GU10 50w lamp holders preferably fire rated and dimmable
I always go for a particular type that 9/10 is halogen GU10 with 90 mins fire rated..! i found a design that i like and can work with very easy! they are in screwy fix for 15 quid or elecy fix for 7-8 quid..! they are good quality and would have them in my house any day!!
I have a CFL and a halogen GU10 fire rated down lights with a lead and plug on each as demo lights and I have both cheap and expensive GU10 led lamps and halogens which I lend to the customers to see which lamps they prefer. I seem to be selling a few more of the CFL's since using the demo lights and a couple of customers have opted for the cheap cold white multi led's. I only offer CFL's or LED's for plastic ceilings or soffits.
I have had a similar problem, the min you mention low energy etc they generally are not too keen. Had a job recently under the building inspector and the customer requested low voltage to which i said this will not pass building regs as you have to have some if not all energy efficient. I told the customer several times and the project manager but they stuck to their guns so all i could do was put it down in the certificate to cover myself.
Personally i feel the price difference is definately an issue.
went on a fire alarm fault recently. care home. they had replaced all the GU10s in the communal hallways with low energy ( fluories, not LED ). had to use a head torch to see the connections in the S/Ds and sounders.
Reply to Jobs that require downlights in the Australia area at ElectriciansForums.net
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
