john guest stat/programmable
  • Thread starter Thread starter toptired
  • Start date Start date
T
toptired
stat was working up until fixing into backbox when the display fails to light up, power was off at time of fix, is there a reset sequence , the manual is only a help if display is on!!!!!!!!!
