U
Unswitched
Hi Guys,
Have replaced a 2-tier MK board in a restaurant today, but the 25mm tails are set solid in the wall with no hope of renewing to meter elsewhere. They are too short and I have temporally joined them with 60A connectors.
Anyone got any ideas of the best/neatest way to extend within the actual board? (just don't reach main switch).
If I was to use crimps, can you get suitable ones for 25mm, and I guess heat shrink?
What about line taps? Are these suitable?
Have thought about: Small henleys within board (too large as there are many ways being used), Soldering & stretching!
Any help guys would be appreciated.
If I use crimps, I think I may need a bigger crimper as mine only go upto 16mm. Can you get 25mm? Must be able to.
Thanks again
Thanks again
