Joining alarm cable behind plaster | on ElectriciansForums
Discuss Joining alarm cable behind plaster in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
A
andusbeckus
I have an new bay window and now the existing magnetic connectors for the alarm are too short to reach the window. The alarm wire needs extending but where the joint would be is going to be plastered over.
Is there any acceptable way of joining the cables behind plaster without having to pull it out and put a new piece in?
Reply to Joining alarm cable behind plaster in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
Luckily when I rejigged the socket to fit the fcu next to it, it meant the original ring wiring reached, i put the socket on the ring and took a...
