joining aluminium to copper | on ElectriciansForums
Discuss joining aluminium to copper in the UK Electrical Forum area at ElectriciansForums.net
sledgehammer
I've not had the experience but I've seen a couple of glimpses of aluminium conductors joined to copper. This was on to busbars and main mccb terminals etc. They'd used lugs I'd never seen before, they also looked to have had a compound or paste in them. Does anyone know much about this practice, the reasons and things to look out for etc. It was fairly large stuff obviously.
something to do with ions being stripped from anode to cathode, where the anode is the metal that corrodes. used in ships with a sacrificial anode to sacrifice metal instead of it coming off the structure of the ship.
We've used various methods, crimp fitting an appropriate lug to both the aluminium and copper wires and bolting together with paste then heavy duty heatshrink is probably the easiest. There's also crimped ferrules available that are designed for Cu-Al connections, google 'bi-metallic joints/connectors/ferrules etc. I've also seen the mechanically fitted lugs and ferrules that have a grub screw arrangement, haven't used them so not sure how good they are.
Reply to joining aluminium to copper in the UK Electrical Forum area at ElectriciansForums.net
My thoughts exactly! Snowed under with work at the moment, so might have to pass it on 😬😬
