Joining armoured cable underground | on ElectriciansForums
Discuss Joining armoured cable underground in the Australia area at ElectriciansForums.net
A
Armourer
Is there a device which can be used underground for joining either 16 mm2 or 25 mm2 SWA armoured cable (2 or 3 core), or do I have to bring the cables up to an above ground JB?
I keep a box of latex gloves in the van for jointing (honestly) as the plastic ones split when I'm kneading the resin. I find that after mixing the resin, which is easier to do when it's warmish, a small hole in the bag is easier to flow control than a large one. Innuendo anyone?
Many thanks for all your answers. The resin kits I've heard about make a lot more sense now but I'm surprised the kits rely on crimping - I was expecting a large screw terminal block inside a completely watertight plastic box.
How do I crimp 25 mm cable securely - do I need a special tool? And any other tips eg for securely fitting the earth rings and strap?
Reply to Joining armoured cable underground in the Australia area at ElectriciansForums.net
I assume said contractor is part of a Part P scheme (NICEIC, Napit, few others..) in which case complain to them. They'll investigate (in theory)...
totally agree
