R
ricosuave
when joining T&E cable with butt connectors do you have to use heat shrink on the joints or not?
Discuss joining cable in the Australia area at ElectriciansForums.net
spot on answer.The heat shrink is required in order to return the cable to it's original condition ie double insulated.
PVC tape is not adequate as this breaks down over time.
If you enclose the connectors in a pattress with cover or similar enclosure then you will not need the heatshrink.
go and wash your mouth out with soap. pre-historic huge brown things with screw terminals.what about a proper junction box ?
- - - Updated - - -
Reply to joining cable in the Australia area at ElectriciansForums.net
