P
pushrod
I have a garden shed supplied with power from the main CU in the garage. It runs down the garden in SWA, everything is in accordance to regs except possibly at a junction between SWA and T&E. The circuit starts off in T&E and on the outside of the garage wall, in a IP rated enclosure, it goes to the SWA. Should there be a fuse here? Or is that just the case just when you join a smaller cable on to a bigger one? They are both the same csa. cheers.
