Junction box wiring | on ElectriciansForums
Discuss Junction box wiring in the DIY Electrical Advice area at ElectriciansForums.net
Stuart McCabe
Hi
can someone help please I have a outdoor sensor light connected to a fused switch in my kitchen the sensor cable goes to a junction box with the following colours red yellow blue and earth then I have a double light switch wire that also goes to the the junction box with the Same colour wires red blue yellow and a earth then I have two lights that have there own cables going to the same junction box with the following colours red black and earth how do I connect all these together please
stuart
I am sorry but it is not possible to specify what particular cables may do over the internet, we could only guess and may get it wrong.
Also you say you have a sensor light and then you say you have two lights and you do not say what effect you are expecting from what switching or control.
The easiest way to progress would be to get someone on site to see the situation and then they would be able to test cables to identify them and connect as you need (or at least as it was).
as above^^^^.
Reply to Junction box wiring in the DIY Electrical Advice area at ElectriciansForums.net
Thank you all for your replies and suggestions. I will try to follow up on each one and find a suitable solution. many thanks all
