Junction Box | on ElectriciansForums
Discuss Junction Box in the UK Electrical Forum area at ElectriciansForums.net
J
Jonmyates
Hello all. I have a 4 terminal junction box that I'd like to use to terminate a second switch cable. How should the junction box be wired? Is it a simple case that each of the 4 wires from the switch cable screws into a terminal?Help appreciated. Regards. Jon
what is the function of the 2nd switch? is it for 2 way switching, or in parallel with existing switch? explain exactly what you want to achieve.
Hi.
In the room there is 1 light, 1 pull cord switch and 1 light switch, both the switches turn the light on/off respectively.
I want to remove the pull cord switch.
Can I use a junction box to replace the pull cord switch?
Cheers
jon
i assume that you want to do away with the pull cord. first you need to see what wires are connected in the pull switch. a photo would help. easiest option would be to just cut the cord off.
Reply to Junction Box in the UK Electrical Forum area at ElectriciansForums.net
Use wago connectors instead, much easier and safer I think
yeah. i think so. Details here..... https://www.electriciansforums.net/threads/havent-seen-tel-for-a-month.210295/
