junction boxes | on ElectriciansForums
Discuss junction boxes in the UK Electrical Forum area at ElectriciansForums.net
B
Buzz-light-bulb
Hello electricians
I'm doing an eicr and Ive come across a cu that has been lowered by a metre and the cables have been jointed through using junction boxes on surface, although its horrible on the eye and personally I Wudnt use this method of jointing. Would this warrant a code 3 or leave as acceptable aslong as the junction boxes are terminated correctly with sheath inside jb and adequately rated with comment on cert what's your views.
Are they accessible?
Are they securely fixed?
Are the terminations done properly?
Are they free from stress?
Are the CPCs sleeved?
Are any switched lives correctly sleeved?
Etc.
Does it need to be coded?
Although I agree it'll look horrible and I wouldn't have picked that method but.....
Good advice here Buzz. Just remember there is a 'Thanks' button. The guys like to feel appreciated...
Can you get a horizontal surface out of a circle? ;)
of course you can. a horizontal line, by definition is a line parallel to the surface of still water. this still water follows the curve of the earth, so a horizontal line is not a straight line. this makes spirit levels and lasers inaccurate, and we should fix everything by eye.
You see tel, this is why you get the big money... ;)
Reply to junction boxes in the UK Electrical Forum area at ElectriciansForums.net
I usually put something like this To assess compliance with BS7671 for continued safe operation (5 year periodical inspection)
