E
Eddless
Can anybody help me please?
I'm servicing a Juno 1-3 fire alarm and the display reads 'Power fault. battery disconnected, check fuse' & 'alarm fault on sounder circuit 3' i replaced the batteries, like for like, but the fuse hold was loose, fuse tested ok. I then swapped the sounder circuits ie connected circuit 2 to 3 & 3 to 2, and the result was still 'fault on sounder circuit 3' ie the wiring was ok, but again the fuse was loose in the holder. I replaced the circuit board with a new one, re connected everything but the 'battery fault' still exists and a new fault of 'Fault, beam detector faulty' has appeared, even though this was tested and worked ok previously. The sounder 3 circuit fault has cleared.
Can anyone give me some advise or tips?
Cheers
Cheers
