P
Peter Woodford
Guys just a few questions need to brush up on a few things
1. A customer has asked for two new circuits to be installed one radial and one lighting circuit they have already had a fuse board change by somebody else i still supply a domesic electrical cert for this don't i.Just the 2 circuits
2. Also if installing fire rated down lighters i take it i dont have to install the fire hoods as well.
3.Am i right when installing lights that all jbs have to be accessible
4. When fitting a light with a pir do i run the unswitched supply striaght to the light fitting and connect the cables in the jb as normal in and out then switch line.
5.When installing outside lights do i need to install some plastic conduit to protect the cable running through the wall and i take it t&e is ok
thanks in advance
thanks in advance
