Just a Quickie. | on ElectriciansForums
Discuss Just a Quickie. in the Australia area at ElectriciansForums.net
Every electrical job you go too do you have to upgrade the bonding if its not 10mm?
Also say if you change a light fitting and the lighting circuit is not rcd protected or upto 17th standard, ie upstairs and downstairs on same mcb will you have too upgrade it?
Reply to Just a Quickie. in the Australia area at ElectriciansForums.net
Unfortunately I don't think you will get an "off the shelf" diagram for the system you are trying to do The Wiser system is very adaptable but it...
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
