Just a thought regarding cables of a past era. | on ElectriciansForums
Discuss Just a thought regarding cables of a past era. in the UK Electrical Forum area at ElectriciansForums.net
Pete999
Northampton
Just a thought really, there have been several posts, where Guys have been asking, what type of cable is this, that or the other.
Now is it just me or do members think we are coming to the end of an era whereby some of the younger Electricians/Domestic Installers, have not seen or heard of the type of cable some of us elder statesmen have experienced.
For example in years to come when many of us Old Lags have gone to the great Electrical Wholesaler in the sky, will there be some other type of cable, especially in the Domestic installation area i,e, non PVC, and people are asking the same questions then as they do now. You can imagine some keen young upstart has come across some 2.5mm2 PVC/PVC cable and wonders what the foook it is.
Do members think that some of the training courses should, at least give some time to the older type installation practices, rather than just teach, how it should be done, and if it bears no resemblance to modern cblas, just rip it out and start from scratch, what do you guys think?
I'm of the opinion, that unless the said domestic cable, resembles a modern copper grey 6242y cable (I allow red & black) it should be ripped out and replaced, regardless of any IR test results.
Cable manufacturers only seem to 20 year life span for their cables, so if I come across something from the 1960's, it's had a fair life and needs replacing IMO.
So for me, when/if we move to another property, and I see anything pre mid 1980's, its getting replaced regardless. Another consideration, regarding the age of a installation cable, is the length of time it may have been exposed to Mr DIY'er. :eek:
This is quite a timely post @Pete999 :)
I was going to post a pic with a query, so here it is:-
[ElectriciansForums.net] Just a thought regarding cables of a past era.
I'm not 100% certain because I've not had cause to open any of it, but based on how flexible and light it feels, and how it sags between the joists, I have a sneaky feeling this is some form of aluminium. I couldn't find any identifying information on it, just the makers mark.
Any suggestions?
Any suggestions?
Looks like the early plastic insulated and sheathed T&E, it had stranded tinned copper conductors with much thicker insulation and sheath than pvc T&E. It is also a lot more flexible than modern T&E
I took a sample, and I've advised the client if it turns out to be aluminium that I'd advise it gets replaced, so I'll have to open it and have a look.
It's the weight that made me think aluminium, it feels so light.
Mr DIYer would have no real concerns with the age of the cable would it? Mr DIY er could ---- up PVC/PVC just as well as VIR /TRS
I think you are right Pete. Our apprenticeship training includes learning about different types of wiring systems and cable, their advantages, limitations and applications but does not really include older types of cable which are no longer installed but which may still be found in use.
Our lecturers' who are time-served electricians may talk about older cable types out of interest and for our information but I do believe it is something they are required to do.
I would always like to know more about old cable types and old installation practices as it is important to be able to be able to identify whether something is safe and fit for purpose.
Thanks for that soms
Youngsters generally don't have the opportunity to work on older sites where it exists or spend a few years with experienced people who can explain or demonstrate historic systems, so yes colleges should show examples.
Reply to Just a thought regarding cables of a past era. in the UK Electrical Forum area at ElectriciansForums.net
Being pedantic, the Crabtree 50A cooker switch is a 4500/1, which has 'cooker' printed on it. For a shower, you require the 4500, which is the...
This same scenario popped up on the forum a little while ago. I’d be cautious of the point on the house rfc where you’re trying to get 2x 2.5...
