Spudmiester
Just been to fit a socket for a girl who lives down the road. Nothing of a job, just one extra socket in living room, and to cut a long story short, it was an extention to a radial in cupboard under stairs, next to C.U.
When I looked at CU to isolate said socket, nothing was marked up so I removed lid from CU (split load) to follow wire to appropriate MCB, and found everything to be on non RCD side apart from outside light, which was wired in 2.5 off a (very slack) 32a breaker. The rest was not much better, boiler wired in 1.0mm and fed off a 16a, all screws on mcb's and tails etc as slack as p*ss.
Did the decent thing and swapped circuits to right sides of board,put on correct size MCB's, tightened up screws, conected socket to existing radial, tested (ze .34), job done !
Now, as I have said before I dont do much domestic, nor am I 'Domestic Installer' registered, so does anything I have done fall under Part P of the building regs.
There were no new circuits,and no work in special locations, but because I re-hashed the already existing DB (no new bits needed), does this make it notifiable ?
Thanks for your input
Spud
Spud
