T
Therolster
Hi all. New to this site. Just been to check out the electrics for a friend that has moved house. Consumer unit is part RCD / part not i.e 16th. BUT he has a totally odd wiring set up for the cooker circuits. Consumer unit has a breaker 32amp for hob and another breaker 32amp, for the cooker BUT the wiring comes from these breakers to a box below the consumer unit that contains two contactors. Merling Gerin Multi 9 CT 40 Amp AC1 415V then into the cooker. The cooker breaker is acting as the switch circuit as well, to engage the contactors. It's a standard electric oven and hob. single phase. This contactor unit looks older than the consumer unit. Could it have been there originally running something more powerful and whoever put the new CU in just used it??
Over to the more experienced chaps amongst this forum AND any answer would be gratefully received.
Many thanks in advance.
Therolster
Therolster
