just registered and quick question | on ElectriciansForums
Discuss just registered and quick question in the UK Electrical Forum area at ElectriciansForums.net
L
ljw
Just to say hi. New here and have a quick question-
My friend lives upstairs in a masonette so her front door and consumer unit are downstairs in her hall way.
She asked if I could put a switched socket coming out of the cupboard where the cu lives.
finally got to the question- would it be ok to run this 1 switched socket straight into the consumer unit and can I use the existing ring main rcd to come out of.
Any help- thanks
Any help- thanks
Yes you can come from the existing ring circuit from the circuit breaker
Any help- thanks
I wouldn't recommend coming straight out of the RCD you won't have any overcurrent protection.
Would be better to come from the ringmain MCB rather than connecting directly to the RCD tbh.
Maybe connect it to the 3rd or 4th MCB on the righthand side of the lefthand RCD making sure the black cable connects with all the other black cable's (there may be some bluey coloured cables there also).
IF any of the above is alittle confusing.....i'd suggest getting a qualified sparks in and get the job done properly before anyone ends up body popping along the hallway.
Maybe we should mention safe isolation procedure. If you don't know how to test for safe isolation don't even think about going any further. If you do then yes you can come off mcb. Be safe.
Sent from my HTC One X using Tapatalk 2
well, i'm in a good mood tonight. 1st decent day's work in 2 weeks just done. paid on the nail, just got to complete his cert.
Its always good to finish the week on a positive note. Been really busy Mon - Thurs this week and have spent most of today doing invoices, certs and estimates so next week is looking good too.
The glass is half full.
Reply to just registered and quick question in the UK Electrical Forum area at ElectriciansForums.net
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
Given that, it probably makes sense to TT the shed, unless you can be sure it doesn't act as an extraneous-conductive-part. (The SWA won't have...
