Cheers for the add,
4th week into level 2 of the EAL, and pracs are starting to get into safe isolation and working on a board to fix 1 way switch etc.
As the pracs carry on - is there a good set of vids that show, in order, the work you will do for the course? Also is there a selection of pdfs which are plain sheet, but with setup you need to achieve, with them being plain, you can write and colour them in with the correct wiring. I think that will either be plain diagrams or pictures. Hope that makes sense.
I do have a thread ongoing in the NVQ's section with my weekly work updates and thoughts, but will finish that off, now I have been added to the trainee section.
Once again thanks for the add!
