Kewtech KT71 or Seaward primetest 100 | on ElectriciansForums
Discuss Kewtech KT71 or Seaward primetest 100 in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
I still havent decided which tester to buy, but decided on the following two
KT71
Primetest 100
I see the KT71 is mains powered, but the Primetest 100 doesnt have 250v test. Which is the best?
ANyone used both?
Don't know whether you're buying new or not, but I'd hang around ebay for a while. I picked up a Fluke 6500 for about ÂŁ250 a while ago which is far better than spending the same money on the KT71 or Seaward new. However, that also does assume you only want to do 240v items and no flash testing. I had a Supernova for a couple of years because I thought I should have a tester that did everything, reality was that I never tested a 110v device or had the need to flash anything.
hope that helps,
Steve
Reply to Kewtech KT71 or Seaward primetest 100 in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Can you show me one that you'd buy... a new one. Cheaper one.
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
