Kewtech Test Equipment | on ElectriciansForums
Discuss Kewtech Test Equipment in the Electrical Tools and Products area at ElectriciansForums.net
Re: Kewtech Test Equipment (Cauton possible Danger)
JUST A WORD OF CAUTION AND POSSIBLE DANGER.
Although I have not tested the 'KEWTECH KEWCHECK 103 MAINS WIRING TESTER Ii have tested a variety of similar testers including an earlier version of the Kewtech tester and the similar Martindale tester. In my experience they all have a fundamental flaw as follows:-
If a socket you are testing has been wired reverse polarity and the earth pin is live. the tester will give the indication that the socket is wired correctly. This obviously is a dangerous situation.
Maybe I should explain further. we have all come across a socket that has been wired reverse polarity and maybe we have all come across a none existance earth for the sockets. The combination of these two faults fools the testerto give the indication that the socket is wired correctly. Needless to say this situation would make all class 1 items of equipment extremly dangerous and a risk of electric shock by touchig the metal casing, yet the tester has given the false indication that all is well.
I would welcome feedback regarding this subject.
Reply to Kewtech Test Equipment in the Electrical Tools and Products area at ElectriciansForums.net
I was at the other end of the results spectrum today. As I was driving home I had a call from my "Mrs Richards from Fawlty Towers" lady, very deaf...
Interesting question & always gonna get different views on this. EICR testing seems to have changed over the years & not by us the Electricians...
