key switch 3 rooms light circuit | on ElectriciansForums
Discuss key switch 3 rooms light circuit in the UK Electrical Forum area at ElectriciansForums.net
thats how I thought myself as well and I told the foreman to delegate the task clearly and efficiently , and he said that Im an electrician and I should do it myself. SO i try to do myself and wish to check if it makes sense generally to make my duty
Your diagrams don't make it clear what you are actually doing, or trying to achieve. What are the key switches doing, what type of cable are you using, what is the purpose of the emergency lighting?
Sent from my iPad using Tapatalk
@ Irina please take a little time and ask a question in the correct format. Look at the above posts and ask your question again.
What is the functionality of the circuit?
Why do you need 3 key switches in 3 different rooms?
What is the circuit?
(as above) What cables and installation methods are used?
Give us all a bit more information and maybe we can help?
Reply to key switch 3 rooms light circuit in the UK Electrical Forum area at ElectriciansForums.net
Fitted a lot of this sort of light recently, with all tests reporting back through central Dali controller(s).
nicebutdim
N
As you've found out, there's capacitive coupling between cores which will induce a voltage into other cores when one (or more) is fed with AC. How...
