Sparks74
Hi
Guys i'm doing a fault find/testing on a modular YMCA,these modular were pre-wired at a factory
& basically i've corrected all the wiring faults,i'm about to start dead testing but i'm a little confused.
The keycard supply is terminated Live & Neutral into the RCBO & obviously go to the key card,but the cpc has been brown sleeved & go to the A1+ on the contactor & the load on the keycard,the key card itself is double insulated,the circuit is wired in 2.5 3 core flex
As far as the test cert goes there is no earth so cant do a r1+r2 or Zs or do rcbo trip times?is this correct or is there some simple easy way around this?
Any help would be greatly appriciated.
