kilo watt hour meter | on ElectriciansForums
Discuss kilo watt hour meter in the Electrician Talk | All Countries area at ElectriciansForums.net
I
izzy76
hi
i got a 3ph 500amp distribution box with 8 63amp3ph isolators feeding other different sub distributions, i need to install a sub kilowatt hour meter on just 3 isolators feeders but dont wish to modify the main distribution .... can i clamp each phase with different current transformers and wire them so they feed a single 3ph 250amp kilowatt hour meter.... is it possible to wire the cts in a way so i can monitor the consumption (in parallel or in series) one ct for every phase respectively ...
i hope i was clear enough
thanks in advance
Reply to kilo watt hour meter in the Electrician Talk | All Countries area at ElectriciansForums.net
I answered a similar question for the client, just looked at all the heaters (2KW per heater) and then asked for their half hour consumption...
Here's a photo of the service head and broader setup. The Myenergi Harvi product caters for dual supply and as such would offer the best of both...
H
It sounds like you have it under control. Just remember that you are required to install an SPD On your main panel which stands for surge...
If you're seeing the 6A DC when you clamp both tails as a live test then it's deffo something within the installation. It's worth remembering that...
J
Apologies >50V :oops:
7K
