KIN WHAT | on ElectriciansForums
Discuss KIN WHAT in the UK Electrical Forum area at ElectriciansForums.net
Pete999
Northampton
There's something I never knew if you bend a wire it makes it hard for the electricity to get through OMG
Thinking logically, resistance will only increase in that area if the CSA of the conductor is reduced as a result of the bend, kink or compression. Sounds like a good experiment that John Ward could do a video on.
Are those fencing samples they've used?
Why not just nail the sucker right through the middle, you wouldn't have it slipping about like that ...
I know mate it doesn't make any sense, mind you nothing the American trades do does, I worked there from time to time, and often had to go away and shake my head and have a good laugh, most of the American Electrician I came across used to get all their stuff from their equivalent of B&Q "Home Depot" and you must know what our sheds are like.
Oh dear, I had heard it was a bit Wild West. Mind you, after your mad Russians a while back, I saw a couple of local boys melting spanners etc on their living room floor the other day ... amazing it didn't end in tears.
BTW - auto spellcheck helped me (not) with turning staples into samples - oops.
That wouldn't be Photonicinduction by any chance? I would worry about it if it was him, he's a very clever man, if a bit mental!
Reply to KIN WHAT in the UK Electrical Forum area at ElectriciansForums.net
Hi Mike, Floating Neutral. I'm really over simplifying below, but using generators as an analogy is possibly easier to understand. In a large 3...
I guess my last post was even less direct than intended.
nicebutdim
N
