Kitchen Fan isolator? | on ElectriciansForums
Discuss Kitchen Fan isolator? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Newcastle Upon Tyne
Hello all
I am currently re wiring a flat which has a damp problem in the kitchen at the rear. I will be installing a 6" extractor fan with a pull cord on it to help reduce the damp. The fan will be supplied from the lighting circuit. I am aware that you need a 3 pole isolator when it comes to bathroom fans (even though I've never read the reg myself). Will I need an isolator for the kitchen fan as well?
Can you not just use a double pole pull cord or does it have an over run needing line and switched line? In fact you could put a 3 pole pull switch in if that was the case but I think they are chunky square things
When I say it will have a pull cord I mean it one which will be attached to the fan. This won't isolate the fan for maintenance/ if there's a fault. I think a Switched fused spur above the countertop would be the best option. That would also remove an ugly pull cord!
Reply to Kitchen Fan isolator? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
as mentioned by Westward a link is the way forward, nothing wrong with that and the pull cord will then be the on off switch.
T
How do I remove the front cover from a Vent Axia extractor fan The model number is not shown, but I have attached an image of the model. There are...
talktalk
T
  • exceeding voltage drop
    The cable is way undersized. If the voltage drop is detrimental to the installation I would make...
  • TT advise
    OK My take on the precautions to implement when omitting an up front RCD on a TT system. Tails...
  • SIL vs ATEX
    Good morning all, I have a question for those who are CompEx and SIL aware - I have various Ex...
