Kitchen fused spurs | on ElectriciansForums
Discuss Kitchen fused spurs in the Australia area at ElectriciansForums.net
T
tt4038
I'm having a new kitchen fitted... I realise it's a good idea to have accessible spurs for my appliances. Thing is I don't want the walls cluttered with spurs. Is there a maximum distance from switch to the appliance, like the idea of having the switches together, like on a grid may be.
single socket for each appliance. the grid switches are double pole , so in case of a fault, each appliance can be isolated. make sure you use a recognised brand of grid switch.e.g.MK, some of the cheap stuff will burn out in no time.
Then you'd have to isolate everything, including the freezer. That's assuming the CU is even readily accessible - it could be above the front door, at the back of a cupboard, or under the stairs behind a load of old tins of paint.
Incidentally this thread is nearly 5 years old, which some people seem to object to.
that's 2 that can count. i'm impressed.:26:
Personally I don't have a problem with resurrecting old threads if the topic is still relevant, which in this case it is.
I know a lot of members hate it though; there was one moderator who went around jump-starting old threads only to close them down as soon as anyone replied; that seems like a pointless exercise.
Reply to Kitchen fused spurs in the Australia area at ElectriciansForums.net
It can be easy to lose the sequence of things. If the fused spur has a neon indicator and this isn’t coming on then I wonder if -the original...
J
The rcd spur being fitted is probably because there wasn't rcd protection of that supply.
