Kitchen island socket back box | on ElectriciansForums
Discuss Kitchen island socket back box in the UK Electrical Forum area at ElectriciansForums.net
Wiltshire
Hi All,
Having a new kitchen and the Mrs wants a socket on the back end of the island, does anyone have any back box suggestions?
The socket will back onto a cupboard so I want to avoid a drywall back box due to it not being very sturdy.
I would appreciate your suggestions. Thanks
Dunk
As well as they usual galvanised back-boxes, you could use adapt something like the MK metal-clad back box to be flush-mounted as it will take the usual white domestic double sockets, etc, and will look a bit nicer from behind (and less risk of catching the back of your hand on any corners).
This sort of thing:
https://www.screwfix.com/p/mk-3-4-module-metal-clad-box/32511
What about a flush mounted worktop socket unit rather than a standard flush socket-outlet?
The thing
Less chance of the socket filling up with unwanted food items etc and can be dropped down when not required. These plug into a nearby socket-outlet and act as an extension lead so are designed for light use such as food mixers etc.
The thing
Hi Strima,
I want to try and avoid a pop up socket because it will take up cupboard space and there's a sink on the island so likely to get splashed
Hi Strima,
OK, I get you now, I thought worktop mounted.
One option is to cut the shape of a 25mm patress box into the unit then use timber at the back to support it. This way you can mount a socket flush and still maintain the IP rating internally in the cupboard.
Reply to Kitchen island socket back box in the UK Electrical Forum area at ElectriciansForums.net
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
An example of the long term race to the bottom of quality of work in our industry, IMHO.
