Kitchen Light Fault | on ElectriciansForums
Discuss Kitchen Light Fault in the Australia area at ElectriciansForums.net
A
alph
Hi guys,
In my kitchen there are 3 separate circuits, one of them the main one (light in the middle has stopped working).
I've changed the bulbs (GU10) and it still don't work.
I've taken the fitting off and checked that there is power with a neon tester, there was.
I got a standard bulb holder and put that in place, that don't work, so the light fitting must be OK.
Any ideas?
neutral missing somewhere down the line check the terminations
Like keithsims says: Neutral fault! If all other lights are funtional on that circuit then the loose connection must be on either the kitchen light or the next fitting down the line towards the distribution board. Don't worry about the metal box lighting up. It's the joys of testing with a neon...lol
It would be worth ÂŁ30 to get an electrician . Neutral faults can be dangerous - I'm sure most electricians have had a belt trying to fix such a problem - its not a job that I would advise trusting a neon tester with
......Don't worry about the metal box lighting up. It's the joys of testing with a neon...lol
NOT good advice. That's akin to saying electricity doesn't hurt.
If ANY cause for doubt exists AT ALL, that a circuit you're about to play with MIGHT be live - DO NOT TOUCH!!!!!!!
Test using an alternative, RELIABLE means, such as with a voltage meter, and if you don't have one, DON'T TOUCH!!!!!!!
It is fair to say that neon testers are NOT a reliable indication of voltage present, or otherwise, but by the same token - NEVER trust an indication from one either. There's a reason professional electricians don't use them.
Against that, sorry, but telling someone not to worry about an indication of potential current or voltage in a circuit is akin to attempted murder in my book. I know that sounds harsh, but consider what would happen if that box is live, and the guy has a pacemaker or something fitted.......
Please, guys. Let's not forget that not everyone here is an electrician, or necessarily competent enough to be safe around electricity.
I agree Bill , we have to watch what advise we give out , someone may get hurt . I answer questions on Yahoo ask and there is always a warning " consult a professional electrician , electricity is extremely dangerous "
Reply to Kitchen Light Fault in the Australia area at ElectriciansForums.net
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
