kitchen lights abd heat damage | on ElectriciansForums
Discuss kitchen lights abd heat damage in the UK Electrical Forum area at ElectriciansForums.net
Hi all. once again i,m looking for some advice from all you valued members, been to look at a job to replace a twin fluorescent weatherproof battern lamp in a commercial kitchen.The heat of the kitchen as caused the lamp to become brittle and actually drop off the ceiling. the twin and earth connecting it as also become brittle. theres no access from above so was thinking of making a small hole in the ceiling to insert a small maintainence free junction box to connect the original twin and earth and some heat resistant flex to connect the new light to and seal the hole with some fire retardant filler, anyone see any problems with this or is there a better way that it can be done.
Regards Daz...
Reply to kitchen lights abd heat damage in the UK Electrical Forum area at ElectriciansForums.net
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
