B
burnside43
Hi,
I just want to get a little advise from you guys - I am an amateur but have wired in lights etc around the farm but they have all had earths etc I am about to installed 6 recessed downlights in my kitchen (not in the ceiling but in the pelmet) the down lights are class II double insulated and dont have an earth terminal. I have some spare slots in my consumer unit and instead of linking in from an existing lighting circuit in my attic (its a bungalow) I intend using a spare 6A MCB in my consumer unit I was going to run T&E to the switch which I will locate to the underside of one of the wooden cupboards and then use the T&E to connect the 6 downlights.
question is
question is
- firstly I intend to connect the earth from the consumer unit to the switch but am I right? is it necessary if the lights dont need an earth?
- Second as I intend using T&E to run from the switch to the lights (I have a roll so might as well use) should I just cut the earth back and use only the live and neutral to connect into the switch and to the lights or do I need to still connect the earth and simply have the earth put into a dead end (lego block) at each light?
