Looking to do kitchen ring sockets in 20mm galv conduit buried within machined chases in the walls. Eventual plan is the whole house (long term vermin issues). Might seem overkill but going the whole hog - only way I'll be able to relax! Ring then goes up into the loft and across between floors to the CU, its between floors where the critters keep getting in.
Anyway going horizontal with the cabling between sockets above the worktops as there are quite a few. My question is this: At the internal corners if I use a pre formed 20mm bend or if I vice form one then I'm concerned that it will protrude into the room. Would I be better to use an inspection elbow as it has a tighter radius? Appreciate that I WON'T obviously be able to get into the inspection elbow because the removable cover will be pointing up and no chance anyway once its plastered over. Using singles by the way.
