Kitchen ring, opinions? | on ElectriciansForums
Discuss Kitchen ring, opinions? in the UK Electrical Forum area at ElectriciansForums.net
imago
Nearly Esteemed
Birmingham
The job is sockets changed in the kitchen and a new CU with upgraded earthing and bonding in a smallish three bed semi. The current installation is in very good condition and basically the outlets side of things are broken down as :-
  1. Ring for garage.
  2. Ground floor ring (four doubles in living room, and a single in the hall) also includes the current kitchen.
  3. First floor ring.
All the rings are wired in 2,5mm T&E and all readings are good (IR, coninuity, ZS).
The integral garage will become the utility room (washing machine, tumble drier, ironing point). The new kitchen layout will have four double sockets above counter with one fused spur for a dishwasher. The hob is gas, and the oven has a separate 6mm radial.
Most of the 'normal' kitchen loads are going onto the utility ring, so given that the kitchen has so few sockets I'm tempted to save them the cost of pulling a new ring for that and keeping it as one ground floor ring for living room and kitchen. So eight double sockets and one fused spur. What're your thoughts?
i agree. it's all too easy to over engineer a job and increasew the cost. as long as your loads are not exceeding your design current for each circuit, that sounds like a plan.
Reply to Kitchen ring, opinions? in the UK Electrical Forum area at ElectriciansForums.net
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
Sure, I'm on the Isle of Sheppey. also the cable they used I think was 2.5 twin and earth, although I could be wrong.
