Kitchen setup | on ElectriciansForums
Discuss Kitchen setup in the Australia area at ElectriciansForums.net
Z
zerozeroseven
Hi guys,
I have the following setup curently:
32A fuse in Consumer Unit, and a 2.5mm ring to the kitcen - only 2 x 2 sockets in the kitchen.
32A fuse in Consumer Unit, and a 6mm cable to an isolator and an existing oven
I want to connect the following appliances _instead_
14kw induction hob
3.5kw oven 1
3.5kw oven 2
fridge (about 5A)
extraction hood (about 5A)
Obviously I need a new 10mm feed for the induction hob from the CU on its own fuse and its own isolator, but whats the best way to connect the other appliances? I want an isolator for each one, since I have the space on the wall ready from them.
I'm thinking I could connect the hood and fridge to the existing ring, use the exisiting 6mm cable for one oven, and run another one to a new fuse in the CU for the second oven.
Or, I could run a second 6mm cable back to the CU to form a ring, and run both ovens off it. This way I save a slot in the CU, but i hear ovens have alot of earth leakage and so this should probbaly be put on the non RCD side to prevent false trips. Is it worth it just to save a slot on the CU?
Its not ideal to split the current kitchen ring, so another option is to run the fridge and oven 1 off one of the 6mm cables, and the other oven and the hood off the other.
What do you guys think? Ideally I dont want to tap into the existing kitchen ring, and would favour a more straightforward layout and sacrifice the fuse slot on the CU if I have to.
Any help appreciated
Thanks in advance!
Great..
So just to be clear....
CU, 45 amp fuse, 10mm cable to 14kw induction hob
CU, 32 amp fuse, 6mm to 3.5kw oven1 CCU, and fridge (5A)
CU, 32 amp fuse, 6mm to 3.5kw oven2 CCU, and extraction hood (5A)
Does that sound ok? The hood and fridge wont be on sockets, but a fused isolator.
Will the 14Kw not overload the 45A mcb if all rings on the induction hob are on full? I make it 61A
page 160 osg, would have to take into account for diversity, anything up to 15kw..... but i know what u are saying!
would make it 26 Amps all in all with no socket outlet on control switch...........bugger to terminate with 10mm though eh! :)
A 32 amp CB for a 3.5kw oven seems a bit high to me, I would install a 16 or 20 amp and a 20 amp rad for the extractor and fridge. If you are installing cables in walls etc they will need to be RCD protected.
ian
Reply to Kitchen setup in the Australia area at ElectriciansForums.net
If your using 35mm or 50mm use 2 core SWA and use the armour as the earth, it'll cut down on price. I know people will comment on this but the...
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
