kitchen sockets | on ElectriciansForums
Discuss kitchen sockets in the Talk Electrician area at ElectriciansForums.net
damien1
how close can u put a socket to a kitchen sink in my mind i always thought that u couldnt have ur hand in the sink bowl and be able to touch a socket at the same time but ive seen loads of sockets very close to the sink where u can touch the socket while having ur hand in the bowl i know ur not supposed be able to plug like a kettle in that is possible to fall in the sink
I've always been told the same, keep it out of arms length. No regs on this matter but if it was a bathroom sink 701.512.3 would give you your answere. Same thing in my eyes, sink, tap, water and the 230v socket next to it? This should be looked at by the powers that be and get a bs code.
problem is , in a small kitchen it is not always possible to have all sockets at a sensible distance from the sink. think it's a grey area where common sense must prevail
Agree, it isn't possible in some large kitchens because people want everything to hand. I have my deep fat fryer in the corner out of the way but I could touch the socket if I wanted to. It's a good comment about the length of flex, that could get a bs code?
what if it's a wooden drainer?
How would the material the sink is made of affect the likelihood of a socket getting splashed? To answer your question it's 300mm whatever the draining board is made of - metal, wood, pottery, plasic... it's still a draining board.
I can't see how the Titanic sinking is any reason to disregard regs.
Reply to kitchen sockets in the Talk Electrician area at ElectriciansForums.net
Hello Ric2013, MJPD29 and westward 10. I have a multimeter that I tested the voltage with and before I open the socket up I use a plug in tester...
