M
martinxxxxxx
Using the exsisting 6mm cable as a sub main supply to kitchen which currently has 3 double sockets (which were connected to to the upstairs ring bizzzarly)
Clipped Direct 6m Run
Putting in a crabtree 63a cu with a 32a rcd ring for the high level sockets and a 20a radial for the cooker (2200w) and fridge.
I have a Zdb of 0.35. So do i need a separate earth ran back to the MET.
Also I know sup bonding is not req in the kitchen, but is it wise to do it in any case?
The sink is quite close to an existing socket
