J
jase31
Hi,
Just planning a kitchen layout. I will chase the walls and put the cable in ready for the spark to connect.
What is the current standard for wiring to a electric hob, and electric oven. The last oven I exchanged, only has a 13amp pre fitted plug, is this now normal? Is the Hob still 32amp?
In the kitchen there will be 3 double sockets within 4 metres. Do these need to be run as a ring main, or can they be radial? What would be the normal wiring size?
