M
Maximus Rumpas
Hi all,
I would like to check something with you. My sister has purchased a 1980’s two bedroom flat in a residential development. There is a single ring main. This was modified around the year 2000 when a new kitchen was installed. 3 additional 2 gang socket outlets and a couple of fuseds pur outlets in the kitchen. Two additional 2 gang socket outlet in the living room and a single socket outlet in the hall. All off these were run as spurs from the ring.
I have removed all these fittings as the work was sub-standard (earth wires not connected, sockets not level, etc., clearly this work was not done by an electrician) I am now left with the original builders ring main.
I would like to install a separate ring main for the kitchen, for convenience this would also supply the extractor fan and heated towel rail in the bathroom.
I have cut back the ring where it enters the kitchen and fitted a flush plate and a label indicating that the wiring behind is part of the rest of flat circuit. This will be hidden behind the new kitchen units.
I would like to keep a single low level socket outlet on the rear wall of the kitchen supplied by the original ring. I suppose this question is about zoning. Is there a regulation which states that all the sockets within the kitchen zone be feed by the same circuit? (in which case it will have to beremoved)
Thanks for your assistance.
