T
timo
Asked to quote on a new kitchen thats been fitted. Existing is connected to house ring etc.
My idea is to disconnect the kitchen from the existing ring and supply a new circuit for the kitchen.
The following will be in the ktc
Around 6/7 double socket outlets
1x extractor
1x Fridge
1x Hob (rating not know)
1x Oven (rating not know)
1x Washing Machine
Going to be updating the CU and bonding aswell as the old is re-wireable fuse etc
My thoughts were to run a ring that will do the sockets outlets, extractor, washing machine. Put a 6mm for the Hob and maybe a 4mm for the oven in case its higher than i thought?
How about the fridge would i be best off putting a seperate RCBO? the cable will be PVC T+E burried in the plaster. Would you put the oven on its own RCBO also?
Thoughts
1x extractor
1x Fridge
1x Washing Machine
Thoughts
