Klik connectors | on ElectriciansForums
Discuss Klik connectors in the UK Electrical Forum area at ElectriciansForums.net
Wales
I have been using a similar product to the klik connector and Crabtree LSC which has 4 pins which insert into the socket and rotate clockwise to connect.
does anyone know what these are called as I can't seem to find them anywhere???
Thanks in advanced
Thanks in advanced
Can't think!
Thought you might have meant Electrak but they are only 3 pin and are a socket not a greg.
Click do a push fit system, but that is just push fit, you don't have to rotate.
With regards to a different job, but connected this these klik connectors.
im looking for a suitable 6A outside plug and socket to connect Christmas lights to for a customer.
lights will be removed every January and reinstalled in November.
i could use commando plugs but looking for something a little more non visable.
These are slightly less visible but do seal well for long term non use.
[ElectriciansForums.net] Klik connectors
Thanks but these don't look like they can stand up as external as when in use the plug is visable.
I will stick to the commando plug I think
You couldn't be more wrong if you tried!! lol!!
These Walsall weatherproof socket outlets are what have been used for wet areas and external industrial installations for god knows how many years now. The plug top is also an IP Rated screwed collar affair. They are also very expensive compared to what i would use in this case, which is an IP66 MK or equivalent weatherproof socket. An example of which is linked here...
Weathersafe IP66 1 Gang Switched Socket| MeteorElectrical.com
Thats closer E54, but I am looking for something different to a plug socket and comando plug as the aim would be to only run 1.5mm SWA (or similar) so wanted to regulate it to only lighting.
Max current draw would be only 1A Max!
As i said, the link is just an example. Some manufacturers just supply the IP rated enclosure, to which you can add say a 2 A or 5 A socket faceplate which i believe are still available from MK and Crabtree. I really can't see the point in that though. as most of the opening covers to these units are lockable....
Reply to Klik connectors in the UK Electrical Forum area at ElectriciansForums.net
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
If you google '4nway led driver' youshould find something suitable. As mentioned make sure the driver is rated higher than the wattage of tape...
Recommended Sponsor News
Hi everyone,
