KNX switches in bathroom | on ElectriciansForums
Discuss KNX switches in bathroom in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
K
knxhome
KNX (aka EIB or instabus) will be used for Home automation of a new home, which is currently in the detailed planning/specification phase.
It is planned to have KNX switches within the bathroom.
The switches will be connected ONLY to the KNX bus, through certified "green" KNX cables of type YCYM.
Would there any problems with installing the KNX switches within the bathroom, either outside zone 2 or within zone 2?
It is my understanding that the KNX bus is SELV.
Reply to KNX switches in bathroom in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thank you..... & did have all the fan isolator/ fuse in same plate (click) so quinetic wouldn't worked on this occasion
This thread can now be closed, as I seem to also have space in the box for the first switch. Revised diagram below. Thanks folks.
