Kubler Codix 6.134 question | on ElectriciansForums
Discuss Kubler Codix 6.134 question in the UK Electrical Forum area at ElectriciansForums.net
IRELAND
Hi anyone help me out with the connections for this counter? I am intending to use it to count the hours on a heating burner in a mates house.
There is a diagram in the link below AC type.
https://docs.rs-online.com/7349/0900766b8147ad9e.pdf
Just a bit of history, I have a crouzet cp2 counter on my own burner which was handy to wire in, round the time of the first lock down I installed the counter to see how much longer the burner would run if left on all day - 6am to 8pm compared to the standard hour in the morning, hour at 4-5 pm and then couple of hours boosted at night. I was surprised to see that the actual burner run time was much the same but the house was warm the whole day.
Id appreciate any help with the connections.
Reply to Kubler Codix 6.134 question in the UK Electrical Forum area at ElectriciansForums.net
Try disconnecting the "central heating off" wire from terminal 2 and insulate it (eg Wago connector or choc block or similar) and tuck it out of...
2 3
4K
