Kilo volt amp can any one explain why we use this if it =kw any way in other words can someone in simple terms explain kva
Discuss Kva in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Sorry E54, but what do you call leading PF! Wattplus power?
It used to be a favourite trick of mine to get an apprentice to watch the incoming ammeter to a plant as I switched off the PF banks. It would then go on to several hours explaining why the current went up and not down as they expected. It was the best way though, as they had seen it with there own eyes.
Reply to Kva in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
